Re: 6 hole fuel sender replacement options
I may have surfed through here a bit later for the OP but will throw my 2 cents out in case it helps anyone down the road.
My company makes tanks (not boat type) and we install standard 5 hole, weld flanges and many times the sending units. We purchase s/u direct from the mfr. so for reference you can get your feet wet pretty good by visiting their web sites to look over the product lines they offer. Rochester Gauge, ISSPRO, Moeller Marine and Teleflex. You can not purchase from them but would need to find a distributor such as the fine folks here at Iboats.
The OP is up a bit of a creek with this old style and perhaps some of the workarounds mentioned above are the best solution as everything else gets a bit costly and confusing. Even though the old unit is rusted up it may be worth some effort to try and clean it up.
In general, a 5 hole sending unit flange and sending unit are designed so there is only one specific match when assembling together. The reason is to take into account direction of swing arm on sending unit so that it does not hit sides, baffle if any and end of tank let alone the drawtube or other internals. Edit I now see you can adjust the float arm in 90 degree increments.
Also, the fuel gauge and the sending unit must have matching OHM ranges in order to read accurately. A very common OHM range is 33-240 ohms. It is also referred to as a Stewart Warner style. But, keep in mind there are others such as 0-90, etc.
There are also a variety of sending units you will need to consider. Some have an adjustable stem and adjustable swing arm. Others, only have an adjustable swing arm and finally some are fixed with no adjustment. No matter the type you will need to insure it doesnt interfere when installed.
I could probably comp you a sending unit flange but that still doesnt solve your problem. Correct method to install would be to have it welded to tank and then tested which is going to run some bucks. I am guessing the tank and boat is older so tank may be terne plate / galvanized and welders dont like working on them as bad fumes let alone s/u flanges are commonly carbon steel or aluminum so dis-similar materials. Then tank would need pressure testing.
I did some searching on web and can find some 6 bolt sending units, looks like Willys Jeep and and some others used them but pricey. Remember would still have to match OHM range to gauge and them make sure could be adjusted.......
I think in one of the sticky notes, just cant remember which forum are a listing of boat salvage yards so possibly could find the exact same s/u but will leave that to you.
Good luck. Just trying to keep the waters clear and hope I havent made this too murky.
