5ph tohatsu to 6hp
Gregoryb
I have noticed in older threads a tohatsu 5hp could be converted to 6hp by a carb. change. Is this still true on newer models? I noticed the part numbers were the same for the 4, 5, and 6. Mine is a mfs5B
pvanv
Re: 5ph tohatsu to 6hp
You would order 3R4032001M, CARBURETOR ASSY, MFS/NSF6A2, $116.52 from any dealer, including me. I always keep at least one on the shelf.
Gregoryb
Paul, appreciate the response. Just a question, the part number through Tohatsu is 3AU03200-0 and lists the same carb. for the 4,5,6; I assume when one orders it designating 6hp is the differance. How do I contact you to order carb.?
TOHATSU GURU
The 3A number is for the newest version of the carburetor...Which you do not want. The 3R number is an older model carburetor that met a lower EPA rating and it was/is/ will be less likely to varnish up.
pvanv
Yes. Run the earlier carb, as it will be more reliable. There are 3 different carbs for each motor series (A vs B vs C). That is to say that it is not the same carb for a 4, 5, or 6 hp motor. They are distinct, and the carb determines the hp output of the motor.
pvanv
Drop me an email at the office: paul@obersheimersails or call 716-877-8221 M-F 9-5 Eastern, and we will be happy to help. FWIW, Tohatsu America is currently out of stock on that carb... but, since I always keep at least one on the shelf, you can have one shipped to you as soon as Monday.
