5hp Tohatsu ID
Scaaty
Have a friend bringing over a 5hp Tohatsu "Saltwater" later today to look over before he heads to the San Juans in his big boat. This for the dingy. He has no manual, but I found a PDF online... I do Mercs and Johnnys, so I'm basically looking at what year.
5hp Model M5B
Ser 369-11215
Thanks..
Scaaty
Re: 5hp Tohatsu ID
Ok, gave a call. The numbers I gave he did not have in the database. Had a ballpark 89-96 on a M5B S, but no M5B. Let me go take a pick of the cowling, maybe then someone can get me in the park on this. Looks like parts might be a prob, but we have a great bearing supply in town that might have a seal for the shaft at least..let me take a pic..post back in a moment..thanks fo the help so far
Scaaty
Re: 5hp Tohatsu ID
OK, heres a cowling pic, and pic of seal needed, and shift seal too. I'll go to Tohatsu Website and see what I can find in the way of any parts numbers too. This motor looks like NEW! But sure wish I could get a year! Thanks again for any help.
TOHATSU GURU
Re: 5hp Tohatsu ID
All 5 B parts are interchangable so the year isn't needed for parts. I can tell you that it is a 1992 or older.
Scaaty
Re: 5hp Tohatsu ID
That helps...at your site, will these parts fit?
Lower Unit Gasket Set For Nissan/Tohatsu, ALL, 4, 5 & 6 hp model & 4-stk 4,5 &6 hp models FREE SHIPPING - LUGS369873210M
If so, I'll order it right now, or if you have the parts I need or close, what other PN should I use..Thanks Elvin..
Scaaty
Re: 5hp Tohatsu ID
THANKS!! Ignore the PM I sent (same info)...
I'll order it right now..thanks again Elvin..Robby
Scaaty
Re: 5hp Tohatsu ID
Well, got the kit today..
Nothing fit that motor L/U. Seals all wrong size, Orings fit nothing...
I'll go through a Bearing/Seal supply house...I'll get 2 15/28/5 MOS and back them in together..
Change your "Fits all 5hp", as probably before 92 its just extra stuff that don't work..
Dissapointed to say the least...
TOHATSU GURU
Re: 5hp Tohatsu ID
The lower unit seal kit does fit all of them. There has been no change in the lower unit design on any 5 B model. What part number seal kit did you receive?
Scaaty
Re: 5hp Tohatsu ID
Well (I am having a hell of a time with outboard parts lately!)
I just went and ordered 2 15/28/5 seals..$25..should work fitting back to back. Then I come here and see your post (this is my fault for not checking first).
YEP, ordered 369-873210M
Guess what was sent?
398-87321-0
This looks more like a base gasket in the bag, so I should have checked...
Wants I send it back ?
TOHATSU GURU
Re: 5hp Tohatsu ID
Send us an email with your order number using our contact button on our website and I will have it taken care of.
Scaaty
Re: 5hp Tohatsu ID
Man, this is turning into a comedy of errors! The guy that I ordered the seals from just called back, and had quoted me the wrong price! So I was lucky enough to go ahead and cancel that order (I try to not cancel an order just because I change my mind..been both sides of the "counter")
I'll email I/O and we can get this straightened out...thanks Elvin..
Scaaty
Re: 5hp Tohatsu ID
Elvin, Thanks...I edited my post above from before...(I'm an idiot for not checking the PN...rough week so far..I'm going out in the boat!)
