5hp Oil Pump Seal Leak
Benjm44
I have a leak from the oil pump cover on my 2016 5hp gas outboard. I figured the seal had gone bad and ordered a new o'ring seal. The new seal seems to be the same condition and hardness as the existing one, and replacing it did not stop the leak.
Both o'rings seem a little small for the groove, and don't look to get compressed by the cover plate. Is there a trick to getting the o'rings to seal well? I torqued the cover to 70 in-lbs as specified, but it still leaks.
Thanks
Benjm44
It is a Mecury1F05221EK. Which I believe is the same engine as a Tohatsu MFS5C.
pvanv
For the MFS5, you need a 3.1mm o-ring:
3R1076050MO-RING, OIL PUMP$2.52
