5hp nissan no run need help
x182dan
Hey guys I recently purchased a 5hp nissan outboard year 1999 and I believe it is a NS5B model. I got it to run with fresh gas and new plug. It ran for a whole 30 seconds to a minute. It ran okay for that period of time but I tried to let it idle and it eventually died. I could not get it to restart at all. Pulled the plug and it was a little wet so I dried it off and still nothing. I did notice the carb is leaking fuel out of the bowl so I think the float might be stuck. Would that prevent it from starting? Any help is much appreciated.
Dan
Sea Rider
Re: 5hp nissan no run need help
If you have spark, definitely needs a good carb clean to start with, buy a carb kit. Carb must not be leaking fuel (bowl gasket issue) could be extremely dangerous to use it that way, could catch fire... Wet plug = floded plug.
Happy Boating
