5hp nissan 2 stroke
BobMinelli
I have a 5hp nissan 2 stroke engine with integral gas tank. when I have the choke closed I can get the engine to start and run but when I open the choke the engine reves and then stops. I have sprayed the carb with cleaner. I have removed the needle valve above the air intake and cleanes that. I have remoced the bronze screw under the air intake and cleaned that. is there anything else I can do short of tearing the carb apart?
