5HP MFS5B Tohatsu will not start
Sakana4you
Motor was running during warmup then died. Will not startup after that.
Have ck the spark, was weak. have change the igniter. Still will not start and spark looks a little low ( little orange not bright blue).
Clean all ground terminal and terminal joints. no dice
Check the fuel pump....OK. Strip and Clean the carburator. Still the same. Need help thanks .
pvanv
Run through the whole motor... electrical, mechanical, and fuel systems. Is the plug wet? If so, probably lack of spark. If dry, probably lack of fuel. Try a spare plug. Sometimes a defective plug can look OK, but have a defect.
Sakana4you
Pvanv
Thanks for all your help that as the problem..It was the spark plug. Need to go back to basic 101
