5hp McCulloch Oil / Gas Ratio?????Help!
randall
I purchased a old boat with a 5hp McCulloch motor and I do not know what the proper oil/gas ratio is? serial number 82090-11, can you help<br />me? Thanks Randall
fone_man
Re: 5hp McCulloch Oil / Gas Ratio?????Help!
lose the "thread" when you repost... just reply to your own post to bring it back up if you think it got lost.....<br /><br />Everything I have checked does not list a 5 HP plus I cannot find your serial, please recheck... This is what I have found<br />MODEL Recommended Product Year Fuel:Oil Ratio <br />McCULLOCH (SCOTT) <br />3.5, 4, 7.5, 9, 12, 14, 14.1, 16, 22, 25, 27, 28, 33, 40, 43.7, 45, 60, 75, 75.2 hp 1964-68 40:1 <br /><br /><br />Model 590/630 1965 16:1 <br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man<br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
fone_man
randall:<br /><br />Check with this guy to figure out what you truly have..... http://web.a-znet.com/scottguy/ <br /><br />
<br /><br /><br /><br /><br />------------------<br />"Keep It Between The Bouys" & "Good Luck"!!!<br /><br />fone_man
Walter
Randall...<br /><br />My source states that if your engine is labled as a McCulloch...not a Scott...it must be at least a 1964 vintage.<br /><br />Quoting Peter Hunn... "In 1956 McCulloch acquired Minneapolis outboard producer Scott-Atwater and jumped right into the boat motor business. In 1964 Scott-Atwater's name (which had unofficially been shortened to Scott) was dropped entirely to make way for the McCulloch label."<br /><br />Peter Hunn's "The Old Outboard Book" does not list a fuel/oil ratio for the McCulloch engines (not that I've found anyway)...<br />Sorry...<br /><br />Walt
corm
Hi,<br />Metal hood with tank on the motor = 30-1.Green motor<br />Metal hood with aux tank = 40-1.Green and Gold hood<br />Fiberglass hood with aux tank = 50-1.Many different colors mostly white.<br />White metal tank on motor = 50-1.<br />hope this helps some. Used to sell-em. Grew-up driving them.<br /><br /><br />------------------<br />...have fun...corm<br /><br />cubic inches = power<br />power = speed<br />speed = FUN<br /><br />Email me if you need to.
