5hp evinrude i.d. with only a serial number
rayiow
Hi,i have just bought a evinrude 5hp angler to go on my 12ft displacement hull boat with cuddy i have no model number on it(plate missing) just the serial number which is C0557079 is this enough to identify this engine,the coweling is white with a red band!!! does that help,will the fuel/oil be 50/1?
OBJ
Re: 5hp evinrude i.d. with only a serial number
Hello Ray, welcome to iboats.<br /><br />Look on the block for a large core plug. The model and serial number will be on there. Post it and we can help.
rayiow
Hi OBJ, all i have on the core plug is the letter M then underneath that letter is the letter C followed by the numbers 0557079.<br />also i have no manual,i have nothing as of yet to tell me anything about this engine
JB
5HP sounds like a pre-1964 engine, Ray.<br /><br />You need to find out the year, because you may need to use a 24:1 mix.<br /><br />There is a web site that has pix, but I don't know the URL. Someone may post it here.<br /><br />Good luck. :)
rayiow
Thankyou JB, here is abit more info but i dont know if it will be of any use!it is a standard shaft, direct drive (no reverse or neutral gears), there is a lever on the right of the engine(if sat in boat)which says stop/start/fast and it uses a external fuel tank only plus it has a recoil hand pull starting mechanism. hope this helps
Paul Moir
Evinrude 'Angler' engines (5hp) were produced from 1965 to 1968. They did not have a full (any really) gearshift like their Fisherman (6hp) brothers. The earlier 5.5hp (also known as Fisherman) did have a full gearshift.<br /><br />Go to The Old OMC Site to try to get a visual ID from their catalogs. Beware that the colours are often not accurately represented. They styling is though.<br /><br />Since your engine has to be a post '63 model, the correct ratio is 50:1.<br /><br />Good luck!
rayiow
Thankyou Paul, well i'm impressed, using The Old OMC Site did the trick, it is a 1968 model with a choice of 5802/5803 model number,now with the serial number that i already have (C0557079)can this be crossed referenced and verified? but thankyou again i am very impressed with the speed at which a positive reply was given, cheers.<br />RAY
Paul Moir
No problem. :) <br />That serial number is consistant with the late 60's - and it seems to me to have been used around '68-'69. I think if you think it's a '68, it very probably is. I'm afraid that's the best I can do.<br />I belive the 5803 is the longshaft version of that engine. If you have a 5" section added between the lower unit and the midsection, then you should use that number. Otherwise, it's the 5802 which is much more common.
