Re: '58 Mercury Mark 10 Mix?
Many years ago I ran my stock MK25 powerhead on a Quickie lower and a 9.5' runabout (just for pleasure, not racing) with TCW2 oil (all they had at the time) and 50:1 regular unleaded. Never a problem. I've always run my old Mercs at 50:1 with no issues at all.
And I quote:
" Q. What is the proper fuel to oil ratio for my old outboard?
A. The currently preferred fuel is the mid grade (89 octane). All post World War II non-racing Mercs (except KB-4's) can operate safely on a 50 to 1 fuel/oil mixture using modern TCW 3 oil. Racing models and the KB-4's should not be run leaner than 25 to 1. "
http://www.oldmercs.com/faq.html#ratio
So if you would, please explain what the difference is in the construction of a MK10, for example, that "requires" the use of 25:1 oil mix when compared to a motor with essentially similar features, an early-60's "Merc 200" with the automatic transmission, which can be "safely" run at 50:1.
Or, a 1958 44 c.i. MK58 and a 1963 Merc 500, which have virtually identical internals.
Or a MK78 and a Merc 700-6 Dockbusters. Had both of them too.
Now, I'm not trying to start some raging argument on this topic but it's one of my pet peeves and you guys brought it up!
Just my $.02 and apparently OldMercs too!............ed
