58 johnson 18hp pressurized fuel tank
T.Lowry
I may have found the correct tank in my brothers garage , it's labled Johnson mile master and has 2 outlets one labled air the other labled fuel,and it has a small pump on top . I suppose I'll hook it up directly from tank to engine w-o coupling to see if it works . does this sound like the right tank? can the correct Quick disconnect fitting be purchased anywhere?
corm
Re: 58 johnson 18hp pressurized fuel tank
They don't make the fittings any more , but do make the o-rings to rebuild them. So your in luck.<br />We do it all the time.
