58 Fastwin Throttle linkage
jsimmons1970
I just finished putting new points/coils/wires/upper seal on her. I'm having a problem trying to get the throttle to sync with magneto plate. I took it a part while replacing everything and plus I had to file/sand the screwdriver grooves out of it! It seems that when I loosing the cam it will slide back but then when I tighten it, it pulls right back to where it was, like the plug wires are stopping it from staying back. Thanks for the help.
James
F_R
Re: 58 Fastwin Throttle linkage
Is the washer under the screw head? Should be.
Joe Reeves
Put a small "star" washer between the metal cam and the aluminum armature plate.
