When I got this motor, it ran well on the tank it came with. The tank is one of the Cruise-a-day pressure tanks.
I took the motor home and wanted to put it on my cuffs (which I'm glad to say, do work on this motor, unlike my other outboard) and make sure I was good to go for a fishing trip (which is in the near future)
Well, I can't get it started. I put the tank on the ground, hooked it up to the motor, pressed the primer button until I had pressure, then tried to start the motor.
It wouldn't start, and there was fuel coming out of the primer button on the tank.
I also noticed air bubbles coming up from around one of the bolts that holds the assembly to the tank.
I pulled the line, pumped the button until it leaked gas, then plugged it into the motor and tried to start it.
The motor fired a time or two and died.
I pulled the tank apart and the diaphragm is fine, the cork gasket is compressed but no obvious tears, and the little washers underneath the screws that hold the assembly to the tank are quite obviously shot.
Does this sound like the tank is just not sealing right? (IE, the tank is leaking sufficiently to not let the motor run. The tank is obviously leaking, but seems to hold some pressure)
