57 Lark water pumping question
john_have
Getting it back together with a new impeller. Here is what the motor looks like. I assumed there would be water from both the top and bottom but I can't find anything to reference.
Any advice would be great.
J
https://youtu.be/SkNt67yc8OA Link of the motor running
F_R
Honorary Supreme Mariner
I give up, how are you supplying water to the pump? Whatever it is, it ain't working.
john_have
I have used ears and a can. My assumption that water should come from that top and bottom are correct then?
oldboat1
Top and bottom, with bottom the exhaust outlet under the plate and top the exhaust port on the back of the leg. It's not happening, and you should pull off the lower unit again and find out what's wrong. Need a fresh impeller, and the copper water line has to be connected in grommets at the powerhead and at the water pump housing.
If new to outboards, try the water pump first in a tub of water (l.u. removed from engine). Rotate the driveshaft clockwise with a portable drill -- should see a good stream bubbling up from the hole that supplies the water tube. While the lower unit if off, rig a hose to run up the water tube into the powerhead -- step down the connection with a piece of fuel hose or similar. You should see water pouring out of the port on the leg and down inside the leg. There is no tell-tale on your motor, unless a PO installed one.
When you put it together and run it, use a 24:1 fuel mix. That's a little more than 5 oz 2-cycle in every gallon of gas.
Run it in a barrel or in the lake, with water about half way up the shaft (a little below the exhaust port). If you get no water from that port on the leg, shut off the motor immediately. Idle or high idle only if running in a barrel.
F_R
Muffs really aren't supposed to work on that motor. However, I was recently surprised to see somebody doing it successfully. But whether they do or not, the fact remains that you cannot test a water pump by running on muffs---on any motor. When running on muffs, the pump merely allows the hose water to pass through. It isn't pumping it through.
Either get it in a tank that is big/deep enough, of get it on the lake where it was designed to run.
john_have
Thanks old boat and others. I got new parts and using your information I was able to get the motor pumping again. the problem was in the powerhead with some debris that I was able to clear. It is running and pumping great. I am excited to get the boat back on the water after the hurricane delay!
Thanks again.
John
