Hello... Some old cars are worth putting big money into but im not familiar with boat engines.. is a 57 18hp evinrude motor worth spending the money to have the carb removed and cleaned... also of note the engine has two funny issues 1) after about 1/2mi of open crusing.. the motors looses rpms and the engine sound is murmered... not like a fuel issue... and 2) when the engine sits for a while and you want to start it, its locked. I mean you have to remove the cover and then rotate the flywheel with your hands to break loose.. after that it pulls just fine... so i dont think its seized up Ive run 50:1 in it since buying used 2yr ago... any ideas on the issue and should I dump $300 into gettting the carbs tuned up???<br /><br />jim
