Re: 55hp powerhead 65 leg ???
If that is the engine I think it is, they made a 55, 60, and 65 with the same bore and stroke. Carbs and props were different for each horsepower. However, changing carbs alone may not give you the extra horsepower. sometimes they changed the bybass and exhaust timing. I am not sure on this engine. To check this, measure down from the top of the cylinder to the top of the ports. If the measurement is the same you may be able to get the extra horsepower with just a carb and prop change. If they are different, the difference will be about 1/16 inch or about 1.25 mm. --enough that you will easily be able to see it. I think all the engines had the same gear ratio. Be carefull! Do not use a prop that is too small. These were probably the best designed power heads Chrysler ever made. These engines develop gobs of horsepower at the low end rpm and with a too small prop, you will strip out gear teeth. Believe me--I have replaced them 3 times. They have weak gears in the lower unit.
By the way-- They made this engine --known as the big bore engine because the bore was 3.375 and the stroke was 2.80 inches. Just like the big 4 cylinder engines. However, The block was packed much better for way better volumetric efficiency. It was made for several years up to 1984 and was made with two different lower units. It also was made with Magna Power II which went bad regularly. You would be lucky to find a good replacement unit. Later models were made with Prestolite ignition.
