55hp nissan prop????
eagle rogue
i was told that if i pulled the prop off of my outboard the size and pitch would be stamped on the back hub. well i removed it and there is absolutely nothing on this prop but an A-1 stamped on one hub and a 14 stamped on one of the ears. how can i tell what it is? i know its 11.3" dia give or take a few. any help would be greatly appreciated
steelespike
Re: 55hp nissan prop????
"back hub" being under the prop nut?
What boat is the motor on?What year motor and boat? Do you have a max rpm and speed?
eagle rogue
being on the back hub i mean toward the motor but that doesnt really matter the only thing on the hub is a A-1 stamp. its an 1987 nissan 55hp. its on a eagle rogue bass boat 15ft. the info i found on line says max rpm on this motor is 5250rpm. i just bought the boat and im in the process of putting on a tach to see where the rpms are. i just need the prop info so i know where im starting from. my local boat shop is the only one around they are less than knowledgable and what they do know they dont want to tell you until you are ready to spend a bunch of money. plus an over abundance of additude to boot. thanks for any help you can provide.
eagle rogue
also if anyone has info on this eagle rogue boat i would love to get something i cant find anything online. there is no max hp plate on the boat.
steelespike
Looking at the nissan prop chart a 14 would be a reasonable size prop.
it is in the middle of the chart 2 spaces toward the high side with 5 higher and I think 7 lower.Seems reasonable for a smallish bass boat.A prop shop can measure it for you. You may have to call around for one in your area.With luck you might find one that will let you test props if you intend to buy one.When you get the rpm and speed figures we will at least know roughly how your setup is and which direction you may have to go for a prop.
When testing note if the antivent plate( just above the prop) is visable on plane.
Or on the trailer the plate should be about even with the bottom or about an inch above.
I wouldn't be going to a marina with an attitude even if I had to go 100 miles.
eagle rogue
thanks ill take it for a test run see where my rpm's are then find a good prop shop to help me out. thank you for the help
