55HP Johnson
JTGP2011
We have this 55HP Johnson motor. Noticed that it is missing some thing.....Hmmmmm
The search is on for parts.......Rebuild
What does this represent?
JTGP2011
Re: 55HP Johnson
I do not believe so, but I do know why you ask the question!
Thank you for the link, will be used.......
Daviet
Re: 55HP Johnson
You're welcome, you can use that link to get part numbers and then check around for the best prices.
JTGP2011
Re: 55HP Johnson
I am having a hard time locating a Trim and tilt for the Johnson.
Anyone?
boobie
Re: 55HP Johnson
Was this mtr used in salt water?? If it was be carefull when taking things apart as they tend to be froze up and break easely.
JSGOLD
Re: 55HP Johnson
So far the major thing I see is the air box and cover missing and those should be easy to find on Ebay. My 55hp (Evinrude) is missing many of the tilt parts and rather than keep looking I just leave the motor down all the time. It never comes close to the ground on my boat and even with a kicker motor it does not cause a whole lot of drag. However I am not sure if all states allow motors to be towed in that position....I suspect ebay might be ahelp there too, or a good CMC tilt. Eventually that is my option, when I can afford it.
boobie
Re: 55HP Johnson
I don't want to argue with you but it sure looks like a salt water mtr to me. Been in Fl 22 yrs and in fresh water for I don't want to say how long. Never seen anything like that in fresh water.
