Re: 55 hp adjustmet Question
AS a startinng point for your mixture screw,tighten it up so it seats the needle,not to tight though, then back it off one 1 full turn and a 1/4. Make sure you turn the screw a full turn not just the slot on the end,(easy to mistake).From here you should be able to find the correct possition by turning upto 1/4 turns either direction.After you adjust ,run motor for couple off minutes before adjusting again,if necessary.When you have it right make sure the next time you fuel up the mixture is exactly as measured before.Because off the age off the motor,they can become temperamental therfore these small things need a bit more care.Good luck,let me know if this helps.
