55 Fleetwin 7.5 not sucking fuel
Thawk
The motor ran, had to replace coils, points and condenser. Now it won't suck fuel. What's the problem?
Honorary Supreme Mariner
Explain in more detail.---------No fuel in carburetor ?------Running with pressure tank ?-------Running with fuel pump conversion ?----------Ceramic filter been cleaned / replaced ?
fhhuber
Start simple:
Gas in the tank? :p
Tank change valve (if you have one) in off position or failed?
Any sign of fuel line restriction? (disconnect between pump and tank line and use something to try and draw fuel through the line)
Bad fuel pump? (Reconnect fuel line above... disconnect at carb and connect an extension to a catch can... activate the pump)
Stuck carb float?
Carb linkage disconnected and carb fully closed off?
Attack it one step at a time... start cheap and work to the more expensive fix.
Crosbyman
are you using a conversion to pump or are you still running on a pressure tank... sucking gas infers a pump
​if it is not pumping... you have few options
1- defective pump
2- pulse line not proving the pulse to the pump
3- fuel restriction from the tank or air leak
4- fuel restriction to the carb
and keep the vent open !
Thawk
I have to pump the tank continuously to keep fuel going to the motor. It seems like it's using up what's in the carb and that's it. Carb is in tip top shape, all new fuel/air lines.
???----Is the cap closed ?----Is the tank building up pressure after motor has started ?
Crosbyman
so manual pumping works ..that's good
not much left...loosing air pressure.... tank leak somewhere, hose crimps leaking etc...
or you have no air pressure ... bad check valve behind the intake manifold. bad gasket ..if you opened it up previously
oldboat1
Pressure tank is a good system -- sounds like your fuel side is working, but not the air. After running the motor even a little, you should hear hissing when you crack open the tank cap. Most of the possible problems mentioned above. Might also pull off the fuel connector, and carefully run a phillips screwdriver in the air side -- should feel resistance from the spring. The o-ring can be a source of leaking (can be replaced).
If the air and fuel sides of the tank supply are working, return to carb. Said to be in good shape, but may need to disassemble and clean it -- all jets, openings and passages.
Crosbyman
I think is carb looks ok because if he pumps the tank manually to send some fuel over the engine runs...
.his fuel needs a push from the engine air pulses
oldboat1
^^may be right. Always potential for related carb issues, though, fuel flow or venting, maybe at a filter bowl.
Compression test needs to be done.----And check for spark that will jump a 1/4" gap on both leads.
