crocket15
- Jul 24, 2007
- 19
I recently bought a lower unit seal kit and impeller for my '55 Evinrude, sadly enough i accidently bought for a 35-hp motor and not a 25-hp. Will the seals and impeller be interchangeable? if only a few seals, which ones? Also, when i get around to taking the lower unit apart, where is the pin or bolt that releases the lower unit?. My guess would be inside the small oval whole that is closed with a plate and two screws on the side of the shaft (about 12 way up the shaft). Are there any websites the have a simple guide or a few pictures to help me get the lower unit off? I feel that i am pretty tech savvy, and should be able to change the lower unit seals with no real trouble, is there anything that will give me a fight?
