55 Chrysler ignition switch wiring
Can anyone tell me the correct wiring on the back of the ignition key switch? I have a 1975 Chrysler 55 hp with a magneto. It is not a magnapower. Model #555HG. I have apparently wired it wrong and burnt my points up. Ordered a new set of points just need to get the wiring corrected so I dont have this problem again. Mechanic I had took it to says the way it is wired I have 12 volts going to points which is wrong. He didnt want to work on it due to the age unfortunately.
Nordin
Re: 55 Chrysler ignition switch wiring
Red-B, yellow-S, white-M, blue-M, green-C. (black, purple and orange not used-for accessorys. Black-ground, purple-tacho and orange-overheatbuzzer). Here is a link to wiring diagram. Maxrules.com-technical spec.-Chrysler/Force technical info.-wiring diagram Chrysler-Chrysler 35-50Hp magneto w/alernator.
aquabob68
is that supposed to be a push to choke switch on that model?
Nordin
Yes it is. Push to choke modell. Think that Chrysler and Force always had push to choke.
