50hp merc power t/t question
corcan1
Bought a older 15ft fibreglass boat made by Tempest which came with a 50hp merc. I believe it's a 1979 thunderbolt 4cyl model.
The previous owner removed the power t/t and rigged up a Atv winch for raising and lowering the motor. The motor runs fine. Had it out a few times with the wife and we're able to cruise along well around 25mph. As soon as we added a third person we rarely were able to get up on plane.
Would a power t/t solve this problem?
Different prop? (need new one anyways)
merc850
Re: 50hp merc power t/t question
I would like to see this winch idea please post a picture! The first thing you need is a tachometer to find out what RPM your motor is turning at, then you can choose a prop that puts you at 5500 rpm full throttle (possibly a 19 pitch one), also, you should be able to run the motor without trim by setting the tilt pin at the 2nd hole out from the transom.
boattriming.jpg.
corcan1
Thanks for the reply.
The boat is at camp which won't be open till mid May. I'll take a few pictures then.
just a simple electric tach will work?
merc850
A marine tach set at 6p and attached to one of the stator leads coming from under the flywheel, NOT the red one.
