simplystressed
- Mar 16, 2009
- 176
I have a carb'd 50hp merc and notice the fuel bulb loses prime fairly quickly after priming it up....whether starting it or not. After priming up I notice I can hear a hissing noise from the fuel pump on the motor where the in/out hoses go. Can't see any gas leaking and the gasket seems tight it almost sounds like its inside the housing.
Is this normal to hear? I'm going to try soap/water around there to see if there is a leak but wondering if its upstream or something in the fuel pump itself causing it to lose prime. Please let me know what you think.
Thanks!
Thanks!
