1995 50HP 4 Stroke EFI Merc. Serial 0G270011
Replaced the spark plugs on motor. It makes a sputtering sound when it hits 3k - 5k RPMs and RPMs start jumping around. Still trying to figure out what is causing that.
So I replaced the plugs. The bottom plug had gas running out of it when I removed it. Hasn't been primed or ran in over a month. Is this normal? Or is the last carb not spraying or firing right? or any other ideals?
