50HP Johnson Overheating
jpbuonomo
I have a 2001 (OMC)50HP Johnson Outbard on a pontoon boat. Both were delivered sping of 2002. This week I was going down the lake at approx 5000RPM when the engine slowed down and started to vibrate. The hot light was ON and alar sounding! Turned the engine off for about 5 minutes then restarted and it was OK untill I tried to go above 2500 RPM. Full stream coming from the telltale outlet. I cleaned the plugs and added some oil to the gas (in case the oil injector failed) and tried again.<br />Strong telltrale strean and again seemed OK untill I tried to accelerate. Again hot light and what I think is "S.L.O.W." mode.<br /><br />My place is about 6 miles from the nearest service facility and I am afraid to go that far with it.<br /><br />ANY IDEAS????<br /><br />Thanks,<br />Joe
OBJ
Re: 50HP Johnson Overheating
Hi Joe, welcome to the forums...<br /><br />I wouldn't take a chance of running six miles to the marina with a problem like that.<br /><br />It sounds like your t-stat assembly has gone south or the t-stat isn't coming completely open. Look right at the top of the head and you will see a four bolt cover. The t-stat is behind this with a diaphram and a couple springs. Try removing the "guts" and running the engine again. If it goes OK without the alarms then the assembly is at fault. Careful when removing the cover, springs will fly if your not careful.
clanton
while you are repairing the overheat, remove the starter and check the pulse hose to the VRO pump. On some engines the starter rubs a hole in the hose, repair hose, grind notch in starter base to clear hose.
jpbuonomo
Hi guys,<br /><br />Thanks for your input, I really appreciate it.<br /><br />I have been looking all over on the internet hoping to find a picture of the "GUTS" of the t-stat assembly. Your description of "springs flying", frightened the hell out of a novice like me.<br /><br />Thanks again,<br /><br />Joe
