lowejohnson
- Mar 16, 2012
- 4
1983 johnson runs great on muffs,put it in the water has no power.will not pull itself onto trailer.I have rebuilt carbs,checked ignition,seems to have low spark on number two cylinder.installed new stator,coils,and power pack.no change,traced all the wiring. even tried second power pack,second pack will not shut off with key.am I just getting bad packs? in the water seems like you are puling a boat behind you.starts good,like I said on muffs runs and sounds great.checked all the grounds too.
