Re: 50hp honda propeller shaft holder removal.
You should be able to just pull on the shaft, but you will have to take the oil plug out so that air can get in, sometimes if there is a lock ring/washer under that nut it can get caught in the threads, make sure you get out first, a slide hammer puller would be the next step.
