50hp evinrude idle adjustment
cmuzzy
I have a model 50173s 50 hp evinrude and it stalls when it is throttled down all of the way. How do you adjust the idle speed or am I thinking about adjusting the wrong thing? I know about the carborator adjustments is that the same thing?
Thanks
tashasdaddy
Re: 50hp evinrude idle adjustment
idle speed stop screw on throttle linkage.
F_R
Watch the linkage on the side of the powerhead whild somebody operates the throttle control. You will see the cable operating a tall lever that pivots in the middle. In the upper half of that lever you will see a long screw with a knurled head. That is the idle stop screw. Do not confuse it with the spark advance screw which is elsewhere.
The proper way to adjust it is to disconnect the cable and operate the linkage lever by hand, holding it against the idle stop. Then adjust the screw for your desired idle speed.
Finally, re-attach the cable and check that it pulls the linkage up against the idle stop when you put it in neutral. If it doesn't, adjust the black nylon attaching nut till it does (without strain).
This all needs to be done with the boat in the water because it will idle at a different speed in the water than it does on land with muffs.
