I have an 89 50 hp that i have had for about 2 yrs motor looks and for the most part run like new . I did a leak down on it when i first got it and it was about 2% even when it was cold! now thats perty good. Anyway i took her to the lake over the weekend and was runnin her around as this is one of the few places i can open it up and all was fine I have a a 6ga. portable tank and i was running low i prob only had about a gal or less so i had a 2 gallon can with reg can so i thru the right amount of oil in the tank for the 2 ga. poured her in shook her up and away we go . I ran her around for just a short time and was coming back into the dock when I heard her cough . I turn the motor off and when I went to leave again she started fine but would immediatly dies when i tried to advance the throttle to go , i started it again and the same thing happed again and again , i goosed her once and managed to keep it going for about 20 sec. Anyway this is a motor that has been starting a little bit harder lately but once it has been run it will always start right off with the first turn of the key. I think i heard her cough once a little bit last time i had it out before this happened , That cough and harder starting is the only thing that might have been a tip off that something wasn't right. Can anybody tell me what is the 90% most likely cause of this, something i can check out myself. I changed plugs about a month ago to the same plug that was in there , I pulled both plugs when i got home they are a little greasy but perty clean ,but not like they have been steam cleaned like with a bad head gasket. I have always put in some seafoam in every tank . Is this a fuel pump issue?
thanks
mark
thanks
mark
