The only way I've been able to keep my motor running when I engage foward or reverse is to crack the throttle open as quickly as possible. I've had the valves reground,which corrected a miss at idle, used a carb balancer, replaced the CDI unit, plugs, fresh gas. Works fine on the muffs, like crap when it's in the water.
