50ELPTO timing issue.
proshadetree
I have a 2001 50 Mercury that I can’t get the timing correct on. It is against the stop at 10BTC and goes out of view at full throttle. Could this issue be related to the ignition trigger
proshadetree
Flywheel key is good, have a new trigger on order. The center magnet assembly looks to be in the same position as a new one. No damage I can see.
proshadetree
Trigger didn’t make any difference. I am going to try swapping coils. From what I am seeing only two coils of the stator charges the CDI or coil. Trigger wheel sets spark time. My thoughts now is either CDI coil or flywheel .
proshadetree
Timing issue definitely was the CDI or coil as I call it. Swapped 3 for 1 timing now adjustable. Suggesting replacing all coils. This unit fires and ohms out. Don’t understand why it would not let me adjust the timing.
