50 Hp tilt replacement - shaft removal
AnonymousGuest
Hi, I'm replacing the tilt assembly on my '91 50 Hp Johnson. I am having a dickens of a time removing the lower stainless shaft from the transom brackets. The top is next & I can even get a straight shot at it with a punch. Yes, I've got a puller on the starboard side, but these suckers are in there to stay. I can only think of using some heat but maybe I'm missing something. I even have the directions from the new kit & it simply says to remove the shafts.
What is the secret???
thanks
boobie
Re: 50 Hp tilt replacement - shaft removal
Heat,heat,heat, a brass drift punch and a big hammer.
