50 hp force
mper
I just pirchased this boat/motor, im not seeing any water come out of the mid section or anywhere. impellar looks good, so dose thermo. can someone pleas help. Thanks
jerryjerry05
Re: 50 hp force
Tach and stuff 001.jpgTach and stuff 002.jpgThe 50 needs a special set of muffs,the big ones won't work very well.
Try running it in a bucket.J
BlkY2k
Re: 50 hp force
Force doesnt have a telltale where you can see a stream of water coming out. At the top of this section under the facs is a writeup to explain how to add one. I just did it to mine and it works great. Good Luck
goodtimesfishing
Re: 50 hp force
My impeller looked fine but passage way was completely plugged, so be sure that you have a clear passage or it still will not pump water. Also if you have it apart put a new impeller in if you don't know how long it's been since it was changed. Just saw a pic recently of a impeller that looked as though it blew up, or busted apart. I am sure the rubber had got real hard from age. Better safe then overheating!
mper
Re: 50 hp force
Thank for your input, i ordered a new impal, thermo, show have in accouple day, will let ya s know how it gose, in mean time, ill make sure my passage way is clear thanks again.
mper
Re: 50 hp force
ok, i cleaned out the water passage, installed impellar, thermo. the motor is cooling great. thanks for your guys !!!!!
