50 hp Force Block Bolts
rhedges
I am looking for info on the bolts used to secure the powerhead to the outdrive. They look like a 12 point torx? Is that stock or did someone put these in aftermarket? Regardless I need to get them out, any info would be appreciated. <br /><br />The outboard is an 1985 50hp U.S. Marine Force, Model 507X5A.
Re: 50 hp Force Block Bolts
dougrussel.com has break down photos bolt, by bolt for most motors on thier site, the nuts and bolts will be listed by size and type....
rhedges
Holy Cow...thanks for the link! I hope this guy has all those parts in stock. I;m rebuilding this very simple motor from the ground up, I just need to get it off the leg so I can take it to the machine shop.<br /><br />Thanks again for your info.
