Re: 50 hp 507F7C starter or starter relay failure?
Thank you both for your considerate, thoughtful analysis: <br /><br />Never reversed the leads, and the red wire was where it should have been (I cleaned rust from off it earlier today. If the starter simply had a short circuit within itself, would circuitous electronic transmission therefore go back to the battery ground and cause the burned wire at the battery negative terminal? I know in a car, a faulty starter solenoid (starter relay in Force application) may be bypassed and the motor will start, even when there is no response at all at the ignition switch. I should check this first, along with the starter, after recharging battery and seeing if charge had just become insufficient.<br />But with full charge before putting into waterway<br />running in a trashcan of water, did same thing-the electrical noise coming directly from engine, presumably within the starter. And I should add that the running lights functioned, but neither the automatic choke (pressing key in) nor starter would engage at all (not even a click or fizz).<br /><br />As for the neutral safety switch, I have not checked it, and appreciate being introduced to it. And a cable straight from battery positive to starter positive is a useful idea, skipping the starter relay. That might isolate the relay. <br /><br />I read on this forum that grounding to the engine block and not the starter terminal works. But I am inclined to keep things factory specs, and not too keen on bypassing solenoid switch - Rather to replace failed electronic components than rig 'em.<br /><br />I appreciate the time and effort you've taken to share your knowledge and experience with Force. <br /><br />Lastly, and as an aside, I've read on these posts that running an engine with low battery charge may damage some electrical components, and I have to wonder if I damaged the starter or its relay by going with to low a charge? And if so, have I also damaged rectifier, circuit breaker, coils? Trickle charged it to start with on 12 volts at 2 amps for 24 hrs., but sat discharged since last November, and I had no reason to keep it charged up from then to now. That'd be 6 months deep cycling to near 0. And maybe 24 hrs. charging wasn't enough for it, considering it sat another week or so before its first actual use in water.<br /><br />Thanks much for reading my ponderous post here. <br />I painfully continue in search of the true cause for the problem and appreciate any/all insights.
