tumbleweed32
- Jun 13, 2014
- 3
Removed lower unit from 1987 50 hp Mercury outboard for servicing. Re-installation should have been straightforward, but for reasons I could not figure out, the lower unit, though aligned properly, would not go in the last1/2 inch or so. Tried turning the flywheel to align the splines but still no go. After having tried to install it and taking it out (about a dozen times) to try to figure out what could be preventing it from seating correctly the second last removal resulted in dislodging a rubber piece later identified as the top seal of the drive shaft.It was placed back onto the drive shaft and another attempt was made to install the LU. Still no luck, but this time another piece came out, later identified as the bottom seal of the drive shaft.
