50 force
bmack4life
here we go again, i have an 89.. i had it running great in the tank the last couple days fires right up, before leaving to take a test ride i started it in the tank for one last run and to warm up before hitting the ramp, it ran for 5 min or less and shut off, restarts only for a second and sometimes wont fire, i have perfect spark on both, fuel system is good (full tank) and fuel filters ar clean, the carbs are getting fuel just fine, any ideas?
WillyBWright
Re: 50 force
Water in the fuel tank? Maybe it ran just long enough to suck it in and die.
bmack4life
Re: 50 force
that was my thought, i cleaned out the carb and had it running good again (it had a spark knock occasionally before) took it for a ride, ran wot for about 2 miles and she died out, the batts. were to low to restart and even with a jump it wouldnt start, towed in, put it right in the test tank fired up with no problems for a couple min and died, back to the spark knock and rough idle, runs a little better with the choke on .
bmack4life
Re: 50 force
it was def water in fuel. upon installing a 10 micron seporator i did a clear and bright and had a cup of 1/2 water 1/2 fuel, so bad it was going through new filter, suck about 5 gallons out of the tank and got good fuel, runs great.. im assuming the cause is the fuel i got, considering it ran great until i filled the tank, what can i add to the fuel to help this from happening again.. (i use 10% ethanol, not by choice!)
