ickeskartom
- Feb 21, 2003
- 21
am looking for carb parts and diagram to see what's missing
1950 5 HP Johnson Model TN-27 Carb troubles?--or too much air getting in the side plate?
Doug here--I am new--first message--and I am probably doing something wrong. Not sure if I can even put my first name, so here goes:
I have this engine and it appears to be in mint condition--bought from a guy who had it in his den for over 50 years.
I rebuilt the mag plate--new coils, new points, condenser, plugs, wires.
I also bought a carb gasket kit, hand made a new float from a fishing cork as the original was rotted. Cranked up and ran perfect for over an hour. Idled good, mid-range good, wide-open good. cooling good.
After running great for over an hour, it set up in a garage for two weeks. Now hard to start and will only start at 3/4 throttle setting and then only run for 30-45 seconds, then quits as though running out of gas or "too much gas". priming it as it starts shutting down only causes instant shut-down. It almost will not idle below half throttle setting, and then shortly and quits.
Not sure what is wrong and don't have another carbuerator to try. It is sure pretty and decals all look very new--paint near perfect, even on prop. I want to keep this thing as it is similar to a "model TD" which was my first outboard when I was a kid.
Any idea what has happend. The pistons appear to be brand new--no gaulding on cylinders (Pulled head when I first got it--also pulled side plate where carb is mounted). It is a "side-mounted" carbuerator with "primer" on top of engine which is also used to set high-speed carb adjustment.
Doug
