Re: 5 hp eska
Does anyone know if I used the new one that came with the kit will work
When your using a thicker or thinner carb gasket it can and will upset your carb sync with your timing advance, it screws with clearance's and that really goes for all gaskets conserning the AV817's, however if you don't have a clue what the 2 cycle Tecumseh outboard engine is suppose to run like "well tuned" I guess it doesn't really matter...but for the record yes it will work but you should re sync your carb which will require you to pull the flywheel to get the job done right.
and for the record other than needle and seat kits sold by Stens and Oregon ( same) there are no
after market parts for the Eska....and for the record the actual correct carb gasket is very thin...the big fattys are knock offs and do for a fact screw with the carb sync,
I love traveling with my laptop
