5 hp eska knock
swampking
Recently no spark and with forum help is running good but i hear occational engine knock..Suggestions for fix or is normal?
JB
Re: 5 hp eska knock
Hmm. You seem to have confused trolling motors (electric) with auxiliary motors (gas) often used for trolling.
I will move this to "Other Outboards" for you.
swampking
Re: 5 hp eska knock
I just replaced plug coil condens points and cleaned all. With forum help finally got spark and running. But under hard throttle I have significante knock. timing? I set and gapped points at.20 but was not sure if the throttle position should be at idle position or ??? "full throttle" Thanks all for patience wihile learning to nav this site as well!
Tom @ Buzzard Bluff
Re: 5 hp eska knock
The reason you're not getting much help on this one is that we can't. In the case of 'funny noises' only the person on site can figure out what it is. It may well be something rattling on the exterior of the motor. Example: a day or two ago I stuck a '58 Evinrude that I'd just replaced the powerhead on into the testank. Cranked it up and it had a bad rattle at a specific RPM. First thought was "Oh no! This used powerhead has a loose rod"! But the narrowness of the RPM range where it made the noise was reminiscent of a harmonic frequency rattle so I messed around until I determined that the throttle advance lever was vibrating against part of the upper housing at a specific frequency. A little bend and the 'loose rod' went away. Good luck!
