5.7L mercruiser engine
Strollin
I have a 1988 century centurion 24.5 ft with a 5.7L runs and idles fine take off and try to get up on plane and my motor sputters and seems to have hesitations could this be a carb issue seems and smells like running rich
Jcris
The more experienced of this forum I'm sure will chime in. That said, the first thing that comes to mind, being an 88', when was the last time the carb was rebuilt? Maintenance is something, right or wrong, that tends to get put off, whether it's my tow vehicle or the boat. The thing about boats is no one wants to get stranded out on the water. To that end, the boat usually gets more love than actually necessary . I'm always doing stuff to prevent breakdowns. So, my humble suggestion would be to at least pull the carb at some point and rebuild it. It may be that it just needs a thorough cleaning and perhaps a new pump assembly. Inspection will tell. Perhaps revisit all external adjustments first? Lets see what the collective has to offer.
Regards
AShipShow
Sounds like a fuel delivery issue...
Whens the last time you changed the fuel filter? Might be time to swap it out and when you take off the old one, pour it in a jar and see if theres any water that separates after a while. In addition, as suggested above, might also be time to pull the carb and clean it and get a rebuild kit... Theres also a filter/strainer at the carb where the fuel line attaches, check that as well to make sure its not clogged.
