Hi guys, I have a question and need some help. I have a 1998 Searay 210 Sundeck with a 5.7L TBI Mercruiser #0L082188. When I first start it, runs great. Once it warms up to about 140 it will load up slowly and die. It then starts right back up and will load up and die again. If I give it some throttle it wont typically do it again until I shut it off and start it again. If I unplug the temp sensor and force the computer to use default values it runs fine on idle. I have replaced the Map, tps, idle control solinoid and temp sensor, still have the same issue. When on the lake it is intermittent. In addition to this problem when I was chasing a backfiring issue, I replaced the plugs, cap, rotor, coil, dist pick up coil and fuel pump. Found out the shift interrupt switch had shorted out. fun fun. Any ideas on the idle? It is not setting any trouble codes.
Thanks
Thanks
