5.7L Black Scorpion Mystery Wire
h20mobius
Hi there... was mopping out a small bit of water from my boat this evening and found the attached wire floating loose... anyone recognize it as a standard wire?
I have a 2006 5.7L Mercruiser Black Scorpion, with a Walter V-Drive.
Thanks so much in advance!
series60
Re: 5.7L Black Scorpion Mystery Wire
Kinda hard to say but it looks like a ground wire. Check the back of the block for a grounding post. There may be other wires grounded to the same post. Hope it's not the + side of the electrical system. Might try tracing it back to whence it came.
Don S
Looks like part of the boat wiring (not engine wiring) to me. Mercruiser doesn't use that type terminal on their wiring.
It also has a covering on it like the rest of the boats wiring. Pull the cover back and see what color the wire is. May give you some idea what it goes to.
