focker1636
- Jul 6, 2010
- 33
I have a 2001 5.7L 250HP Mercruiser Alpha One Gen II, which has started overheating after running a while on the lake. The boat has never been run in sea water. We typically have a pretty full boat. The engine typically runs @175 degrees, but over the holiday weekend the temperature started rising above 200 and the warning buzzer was triggered after run WOT for a while. This occured several times.
This happened a couple of times last summer. Prior to the summer the boat was serviced and the impeller was changed. The engine has @110 hours and sounds great otherwise. No sputtering or coughing.
Pretty tight on cash. What things should I look for? Thanks.
