winbasic
- Jul 4, 2006
- 125
Hi,
I've just returned from a day trip and for 99% of the day, the engine performed without any problems at all. We ended up doing about 3 hours total running time averaging 22 knots at around 3,400 rpm and averaging 40 litres per hour fuel burn. Temp was fine, oil was fine and no signs of anything being wrong.
When we started the boat, we idled for about 5 minutes then took about another 5 minutes to get out of the Marina at about 4 knots. When I put the throttle down to get up to the above figures, the engine appeared to be missing and generally running rough. We had to slow down to 6 knots for a speed restricted zone and after that, it was still missing and rough running probably for another 10 minutes before coming good.
Plugs are only 10 hours old and its got new oil and oil/fuel filters - no loose connections and as the first paragraph says, most of the day it ran fine. What sort of things should I be looking for to try and work out what's going on?
Thanks in advance!!
David.
Thanks in advance!!
David.
