5.7 - Sea water pump replacement - Rookie mistake :(
Mini hog
Just replaced the sea water pump (housing and impeller) but I made a rookie mistake. I forgot to mark the hoses before I removed the old pump.
How do I make sure that the hoses are connected to the correct outlets on the pump housing?
alldodge
BT has you covered, but can also look on the back of the housing, Most all motors are now Left Hand Rotation and only if you have a very old boat will you run into a RH motor.
Mini hog
Great! So my 2001 5.7 LX with Bravo 3 should be LH rotation. And the hose to the cooler connected to the LH out and the inlet hose to the RH out.
