Hey every one,
i have a 2 year old 5.7 Mercury MPI motor with Alpha One out drive exclusively running in salt water.
Two weeks ago it run great all day, last weekend it started overheating.
I suspected a faulty thermostat, so on the water i pulled it out and tested if i can make a day without a thermostat. (i read now that it is not a good idea to do so)
I was able to run up to 1800 rpm and staying at 180 degree engine temp. We trolled and fished without a thermostat like that for about 10 hours.
Next day i replaced the impeller ( old one was still in mint conditions with no sign of wear) and the thermostat. (tested the new thermostat in boiling water for function)
i thought my issue would be gone but just to make sure i checked on the nearby lake today with the result that the engine still overheats.
Engine runs great in my driveway with no signs of overheating.
Water flow seems to be normal at exhaust!
At idle up to 1500 rpm engine stays in good temperature range. (under load on the lake)
Little above 1500 rpm temperature climbs up to 200 when i shut it off.
After every use i flush the engine with Salt Off. and after water cooled off i drain the water out of the engine. ( boat is in my driveway)
What should be the next step to look at? I am a bit lost here at the moment with fishing in full swing.
Any help will be much appreciated.
Thank you very much
Daniel
Thank you very much
Daniel
