5.7 mercruiser alarm warning panel wiring
clerihew82
I have a 1998 mercruiser 5.7 with carb. Last couple of years my alarm has been going off at different times. Sometimes while idling and sometimes when on plane. I want to add some led lights on my dash with each one of the alarm senders so I can see which sender is alarming. Does anybody have an idea how to do this? Do I just come off of the sender wire with a wire and to the led and ground the other side?? I want to do this for the temp sender, outdrive oil sender and oil pressure sender.
wrench 3
Re: 5.7 mercruiser alarm warning panel wiring
You would need to run two more wires from the engine to the instrument panel, install three diodes to stop them from back feeding into each other but still operate the alarm, and run ignition feeds to the LEDs.
If the problem is fairly consistent, why don't you just disconnect the senders one at a time and tape the wire back. When the false alarm quits, that's the culprit.
Nope,... The Senders provide the Ground, ya got it backwards....
Like Wrench says, just Fix the problem, insteada re-engineerin' another nightmare...
clerihew82
It is never consistent. I've tried disconnecting senders but it may be every four or five times that I take it out that it will sound. I'm sure it's a wiring issue and checked all connections but can't trace it down.
Ayuh,.... Disconnect the sender from the drive oil resv., 'n Run it...
That's the Most likely suspect....
Don S
Did you disconnect senders or the alarm switches. Two different things,
Remove one at a time the temp switch (not gauge sender), oil pressure switch, and low gear lube reservoir sender. One of them is not working properly and going to ground, which causes the alarm to sound.
clerihew82
I disconnected the wire at the senders itself. This was last year so I'm trying to remember the wires
Don S
The wire you disconnected better be tan with a blue stripe, or you disconnected the wrong ones.
