5.7 GSI with SX-M sterndrive sea water intake and exhaust
dmw0215
I recently rebuilt the motor and now I keep tearing up pump impellers. It all started with bad gas. After cleaning the fuel system my father was reving the motor in the yard to blow all the crap out of the motor. It seemed to be ok so we took it out and we put a load on it. It suddenly dropped from about 3500 rpm to only running at idle and we tried to limp it back to the dock apearently the temp guage wasn't reading right and we ended up with an engine fire. We rebuilt the motor and we had to replace both the exhaust bellows and the drive boot along with the shift cable that had been burnt so bad it had seized and melted but the outdrive seemed ok otherwise. We have since burnt up 3 sea water impellers in less than a half hour each. It seems to be running extremely rich and I can smell gas in the exhaust water when running it in the yard. We thought the fuel may be due to the fact it hasn't been broke in yet. We found a small kink in the hose coming from the outdrive that brings the sea water into the transom and fixed that. Thinking it was ready we put it in the water last night and when we started it water poured out of the weep hole in the sea water pump and it started overheating so we pulled the sea water pump. It was destroyed. Trying to figure out why we've been tearing up pumps we started the motor with the pump housing off to see if the shaft was bent or wobbling and the strangest thing happened. Sea water and coolant along with exhaust started shooting out of the sea water inlet hose. The only thing I can come up with is that there is some kind of gasket in the foot that seperates the intake and exhaust lines that has failed allowing exhaust into the intake tubes. As for the coolant, I'm thinking a rupture in the heat exchanger. Thanks for reading. I wanted to make sure the history was understood. And by the way, there is no oil in the coolant or coolant in the oil. The rest of the motor seems solid.
Don S
Re: 5.7 GSI with SX-M sterndrive sea water intake and exhaust
Are you running on muffs in the yard? The thing that burns up impellers is lack of water. If on muffs, air leaks on the suction side of of the pump system somewhere between the pickups and the pump. Or, you may not have enough volume of water for the muffs.
This overhead diagnosis file should help you find the problem. http://www.4shared.com/file/50572185/e88f1d89/Volvo_Penta_Overheat_Diagnosis.html
dmw0215
Of course i'm running muffs but that is not the issue, i have never burnt up a sea water impeller until now, and the real concern is ...... WHY when i ran the boat at the dock with the sea water pump off did i get coolant and exhaust (a lot of it) come out of the sea water inlet hose? With the sea water pump off there is nothing to draw anything up that hose. to be clear the inlet hose attaches directly to the foot and goes straight to the pump and if i'm correct it should be a straight shot from the top of the foot where the hose attaches to the inlet holes at the bottom of the foot. I'm thinking that inside the foot the exhaust is redirecting to the intake tubes due to a gasket failure or worse, have you heard of this happening ? i cannot find any info on the subject... not to mention how is the coolant getting to that hose ? i'm positive that the motor itself is in good shape, it is isolated to the cooling system and possibly the foot, that is the only place that both the intake and exhaust even get close to each other is inside the foot, i may answer my own questions when i tear the foot apart
